PCausey
I recently did some trading and wound up with a David Brown (Case) 885 tractor with front bucket. The front bucket works fine but I'm having trouble with the 3-point on hydraulics on the rear. They worked slowly but did work at first although it took some playing with the valve to get it to work and then as I was working the tractor with my grader blade first it took awhile to get the 3-point to lift again and then once I got it to lift all the way I cannot get it to release and lower again no matter where I move the control valve to. The control valve I'm referring to switches the hydraulic control between the 3-point and the front bucket. I'm thinking the valve is not working properly and not opening the return side from the 3-point back to the reservoir but I'm not sure. Has anyone dealt with this problem on this model before? Is there anything else I should be checking? Thanks!
