Davco Brush Cutter
   / Davco Brush Cutter #1
KiotiAcres
Hello all,
Anyone have experience with a Davco Brush cutter? It's the closest thing I can find to a mulcher for rental in my area (Nor Cal). Wondering if its end result will look more like a mulcher or more like the results of my CUT's rear rotary mower.
Looks like it will be mounted on a bobcat T250. Will be going after coastal scrub brush, up to about wrist size and slightly greater diameter.
TIA<
T
   / Davco Brush Cutter #2
   / Davco Brush Cutter #3
The Davco Head throws material can be dangerous They have band it's use in some areas to the material throw. It is a slashing procedure and leaves untouched material Fecon have introduced a FRM70 Head which is way better
Fecon
   / Davco Brush Cutter #4
Rotary cutters are not comparable to mulchers. I have a brushmonster high flow. I bought it new and haven't used it but a few times. The rotory cutter is only comparable to a bush hog (a souped up one). It will leave large pieces and stumps, stubble, etc. It awesome if it's all you have... but if you have a mulcher you'll only use the rotary cutter to reach across an occasional ditch you need some extra reach on.
2019 FREIGHTLINER M2 106 REFRIGERATED TRUCK (A52706)
2019 FREIGHTLINER...
2003 Paris Utility Trailer (A52377)
2003 Paris Utility...
2010 Ford Fusion Sedan (A51694)
2010 Ford Fusion...
1998 INTERNATIONAL 4700 4X2 LIQUID TRANSFER TRUCK (A51406)
1998 INTERNATIONAL...
2017 Kia Cadenza Premium Sedan (A51694)
2017 Kia Cadenza...
