Dash Lights
/ Dash Lights #1
hagman
Central, IL
B7610 Kubota
Morning All,
The left side of my dash has no illumination with my B7610 Kubota. Does anyone know if there is a seperate fuse for each side or is it more likely that I have a bulb/s out?
Hagman
/ Dash Lights #2
I would suspect that a trace lead for that side is cracked and broken. Or the bulb. Could be a funky socket as well. These tractors have a good amount of vibration that could crack the PC board that the lamps and instruments are mounted on.
/ Dash Lights #3
With out a wiring diagram its just a guessiing game, but I would be surprised if the side that is out is on a diffferent fuse. How hard is it to get the panel apart? On my JD the hood has to come off to get to the screws. My oil pressure light didnt work, luckily it was the oil pressure sender which was was easier to swap out than the light bulb. More money but less hassle.
2013 Komatsu PC360LCLC-10 Hydraulic Excavator (A60352)
2013 Komatsu...
1035 (A61166)
1035 (A61166)
UNUSED WOLVERINE SB84-84" ROCK BKT (A62131)
UNUSED WOLVERINE...
2016 Komatsu HM400-5 44 Ton Articulated Dump Truck (A60352)
2016 Komatsu...
New/Unused Landhonor 20ft x 20ft Carport with Side Walls (A61166)
New/Unused...
2021 Kubota SVL 97-2 Skid Steer (A61166)
2021 Kubota SVL...
