dash light
   / dash light #1
pipe_welder
western N.Y.
Kioti Ck 25
Does anybody know what the red light with zig zag across it means. It's just under the high beam light on the dash of my CK25 gear. We moved awhile ago and can't find my owners manual. Any info would be helpful.
   / dash light #2
Low coolant level in the overflow reservoir. There's a little float in there. I've had to add a little bit about once a year for some reason.
   / dash light #3
Believe that is the alternator indicator. If you increase RMP, it might go out. Check the belt tightness if it does. If it doesn't, you might check it with a meter to see if the alternator is putting out a charge (13-14 amps).
Just saw Joe's reply - I'm talking about the lighting bolt type icon. The one he references looks more like a rectangle or square with rippled lines through it. Either way, you've got the answer.
   / dash light
wow that was fast guys thanks for the info. Ken you must be close to me I live just outside Olean.
   / dash light #5
Deposit for me. Middle of NYS but on the southern border with Pa.
Year: 2016 Make: Ford Model: F-450 Vehicle Type: Pickup Truck Mileage: 222,981 Plate: Body Type: 2 (A51692)
Year: 2016 Make...
Magnum 4000 Series Hot Water Pressure Washer (A47384)
Magnum 4000 Series...
2012 Ford F-250 Ext. Cab Omaha Service Truck (A50323)
2012 Ford F-250...
UNUSED CFG Industrial XZ20R Mini Excavator (A47384)
UNUSED CFG...
2024 Icon I40L Electric Cart (A50324)
2024 Icon I40L...
Manac Walking Floor Trailer (A50322)
Manac Walking...
