MadReferee said:
Close but no cigar. In most areas of the country off-road has been the same blend as on-road, only with the dye added. With the switch to ULSD and the very limitied availability of LSD (500 ppm fuel), just about everyone will be selling dyed ULSD as their off-road offering because that is all they will be able to get. LSD (500 ppm fuel) will probably become more expensive as it becomes scarcer and scarcer due to the small amount of it being refined.
ULSD will work just fine in your tractor.
It most likely means that it is dyed and no federal and/or state road tax has been applied. As to the suplhur content it may be LSD or ULSD. You have to check at the pump.
All of the above DOES NOT APPLY TO CALIFORNIA. In California all you can get is ULSD for any application, on or off-road.
Maybe I'm all wet, but I have a theory on this. I too buy off-road diesel
to avoid the 60+ cent/gallon PA road tax. Works fine - recommended to
me by the local tractor repair guy I bought my 'bota from. But, this last
container full does seem to smoke a bit more and have a little less
"oomph" - not so much that to be readily measureable, but different.
So my theory is that we are now getting the last dregs of the LSD
tanks as all refineries clear out old inventory. That would tend to be
more highly contaminated with both water and, well, crud. My
understanding is that it *all* has to be ULSD going forward.
Might prove myself wrong if things continue this way in the next few
months - or just that my
B6200 is showing it's age - but then so am I
Just my $0.02 - your mileage will probably vary.
