Dang it!
   / Dang it! #1
DickLucky
Yanmar ym1500
I recently purchased a Ym1500. It sat in doors for yrs. Anyway both sides of the brakes were locked up. Tractor wouldn’t roll at all. So my only option was to figure it out. So I got both assemblies out and tractor now rolls freely however I busted the right side cast brake cover. And now I’m feeling pretty dumb because I can’t seem to find a new one. Can anyone please help me?
   / Dang it! #2
Take all the pieces to a good welding shop and have them braze it all back together.
A good fabricator should also be able to make you a replacement.
If you lived close by I would say bring it over.
   / Dang it! #3
And if that doesn't work, and since it's cast, go to one of the foundry or blacksmith forums for hobbyists and see if you can find a hobbyist that will cast it for you. There are a few that cast small quantities of iron and steel.
   / Dang it! #4
@Yander I need you to put out the Bat Signal to attract all the other folks that have Yanmar in their username.
   / Dang it! #5
@bmaverick can introduce you to the
   / Dang it! #7
I would get it brazed if you can't find a replacement. That's not a high stress part, it will be fine.
But go to a specialist and get it done right.
   / Dang it! #8
It's too bad you broke the plate. But it would be an easy repair if only 2 or 3 pieces. Any decent welder could do it.
Eric
   / Dang it! #9
Hope you get it back up and running soon.
3in Poly Pipe (A49461)
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
MEGGER EZ THUMP (A50854)
MEGGER EZ THUMP...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2013 Doyle Dry...
