DAMAGE DUE TO REAR WHEEL SPACERS
   / DAMAGE DUE TO REAR WHEEL SPACERS #1
dhagerty
Simple question: Has anyone broken anything on a BX-24 caused by the installation of rear wheel spacers? Not dual wheels, just spacers.
If so please reply with what was damaged and what were you doing when the damage occurred.
If not you do not need to reply, view this as a survey. Lots of chatter on this topic but interested in hearing from those that actually had failures.
Thanks, Happy Holidays
   / DAMAGE DUE TO REAR WHEEL SPACERS #2
Bump, because it's nearly a year and a half later and I'm very interested...:anyone:
   / DAMAGE DUE TO REAR WHEEL SPACERS #3
I've been running spacers for two seasons now and haven't had any problems (knock on wood). What I do have a is a much more stable and safe platform to work with!
Now that you have me thinking, I'll have to pull the wheels sometime soon and check for anything out of the ordinary.
   / DAMAGE DUE TO REAR WHEEL SPACERS #4
Thanks Al. Richard from Bro-Tek says he's had a pair on his BX22 since 2005...over 1,000 hours of heavy testing, with no problems. That's a pretty good testimonial.
   / DAMAGE DUE TO REAR WHEEL SPACERS #5
These things home made, or does Kubota actually make a spacer for their machines??
   / DAMAGE DUE TO REAR WHEEL SPACERS #6
Two years with 2 inches spacers on my BX2350 without any trouble.
The tractor is much more stable.
   / DAMAGE DUE TO REAR WHEEL SPACERS #7
Any difficulty R&Ring the MMM
   / DAMAGE DUE TO REAR WHEEL SPACERS #10
How much does it add to the rear width? Do they also offer front spacers?
Russ
The factory spacers should be 1.5"... So 3" total... Aftermarket spacers, most notably Bro-Tek, are wider.
The factory spacers are made to allow enough space for the installation of tire chains. And they are not compatible with all MMM deck widths.
Regarding front spacers... They would not give you any advantage. The stability of a tractor is dependent on the rear wheels.
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
3 PHASE SEPARATOR (A52472)
3 PHASE SEPARATOR...
6000 GAL FUEL SKID (A52472)
6000 GAL FUEL SKID...
2017 MITSUBISHI OUTLANDER SPORT (A52472)
2017 MITSUBISHI...
LMC LOT NUMBER 140 (A53084)
LMC LOT NUMBER 140...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
