daily drain fuel sediment bowl
   / daily drain fuel sediment bowl #1
ugabulldog
GA
'04 MF 451 diesel shuttle shift w/ MF 1040 loader
Tractor manual says to do this, has a thumb screw at bottom of bowl. Who else does this regularly? Also, should I do this with tractor running or off? Don't want to get any air in diesel lines!! (Tractor doesn't have a manual lift pump as far as I can tell, I have looked everywhere and doesn't have one where manual shows it should be.)
   / daily drain fuel sediment bowl #2
Drain the sediment bowl with the tractor off. I never did it on a regular basis. Not very often at all.
Daily drain? Even monthly, if a tractor sediment bowl needs draining that often, there is a serious fuel contamination problem either with the fuel distributor or the tractor owners fuel storage or the tractor's fuel tank.
   / daily drain fuel sediment bowl #3
You're not likely to get air in the lines by draining the fuel bowl at the petcock at the bottom of the bowl. It's there to allow you to get sediment or more importantly, water out of the fuel flow to the fuel distributor and injectors.
If you're changing your fuel filters as required and your diesel is clean and free of any water or contaminants, that is your best bet to keep your tractor running well.
   / daily drain fuel sediment bowl #4
WoW! I've had two tractors here for over 35 years and have NEVER drained the fuel sediment/water separator bowl. Both tractor had clear glass bowls so you could see any accumulation of sediment or water and I never have had any.
You actually need to collect some of the fuel you are draining out of the sediment bowl and see if there is any water or sediment in the fuel. Its very difficult to believe that the fuel you are purchasing or that your fuel storage techniques are so bad that daily purging is necessary.
   / daily drain fuel sediment bowl #5
Mine also has a clear reservoir, and I just visually check it.
   / daily drain fuel sediment bowl #6
I don't remember the last time I replaced a filter or drained a bowl on any of my tractors. Diesel fuel filter membrane is too small to allow water molecules to flow through and if you use clean diesel from clean tanks with a final filter at the output of the tank there won't be any water there to drain anyway.
Lots has changed since a lot of manuals were written....lubricants especially.
2019 Ford F-350 Crew Cab Knapheide Service Truck (A42742)
2019 Ford F-350...
2014 FREIGHTLINER CORONADO (A45046)
2014 FREIGHTLINER...
Ford NAA Jubilee Tractor (A44789)
Ford NAA Jubilee...
2005 IMS 5012 LP VERSI DREDGE (A45046)
2005 IMS 5012 LP...
2018 Chevrolet Traverse LS SUV (A44572)
2018 Chevrolet...
2020 Ford Mustang Coupe (A42744)
2020 Ford Mustang...
