D850 questions
/ D850 questions #1
John White
Newark, Oh
Bob Cat Ct335
I just purchased a light plant generator with a Kubota 850 engine. Do these engines have a governor? If not can one be added.? I noticed that when I increase the load on generator, it does not seem to pick up speed. The only way I see to increase the speed is with the lever on the side of the engine. Which is not good because I dont want to be running outside and increasing the speed every time a load is applied. I changed the oil and used Shell Rotella 15-40 but some one said I should have used 10-30. Any help appreciated.
/ D850 questions #2
These engines do have a govenor but they are somewhat lazy. Not so good for a gen. A generator governor can be put on but I think a diesel shop would need to do it. Unless of course you have a better understanding of the innards than I do.:D
2005 Pequea Trailer Model 716 Deckover (A63116)
2005 Pequea...
2022 Belshe WB14 18ft Trailer (A64047)
2022 Belshe WB14...
2010 HINO 268 4X2 S/A NON CDL 26FT BOX TRUCK (A59912)
2010 HINO 268 4X2...
TAKEUCHI TB240 EXCAVATOR (A64279)
TAKEUCHI TB240...
Worksaver 48" Tractor Grapple w/ 12V Actuator (A64047)
Worksaver 48"...
2017 Ford Fusion SE Hybrid Sedan (A61574)
2017 Ford Fusion...
