griz
Hello everyone, I am needing some more opinions. As of now, I am looking at the above two tractors and running in circles. I like both but have a few concerns as to which way to go. I will be using it around a construction site (backfill, landscaping, gravel roads) and at home (40 acres 1/2 woods and 1/2 pasture, fairly steep hills and flat) I like the 4310 its smaller wich may be good in getting around tight fits and such. Another advantage is the quick-detach sub-frame JD bh. The d40 would have a 3pt hoe wich I am a little concerned about for saftey of me and tractor. The d40 has 800# more lift capacity on the fel and of course it is a little larger frame tractor with 4cyl. I was wondering if anyone has used the 4310 as I would, or know if I would be disappointed in the fel performance? I guess the kink I'm running into is my budget I can afford the 4310 with fel and bh, but not the d40 with fel and bh.( just fel). The 4510 is way out of my $ range. My bh work would be light -med. duty (trenches, small stumps, etc.) Is it better to go larger tractor with less implements or smaller with more? This is alot of $ for me so I want to do it right. Sorry for such a long post! Thanks Griz!
