A D3B should have a split master link. Then you just take the 4 bolts out that also hold the (special) master link track pad on. Look for the solid link on the track. If not, maybe there's enough slack to loosen the track and just pull it off without taking a master link out? A portable track press would be the easy way if you can get a hold of one. I put new sprocket rims on my 931B. Measured carefully and cut the old teeth off with a torch. Beveled the hub and the new tooth ring and welded them on in place. You have the option of segmented teeth but I think you need a different hub. To get the hub off, you need about a 20 ton puller as it fits on taper. If your rails are worn will wear out a new sprocket a lot faster.
