D2350FD MITSUBISHI
   / D2350FD MITSUBISHI #1
Canturanch
Orange Grove, Texas
D2350FD MITSUBISHI
Searching for a radiator, top hose left side bottom hose right side.
   / D2350FD MITSUBISHI #2
Finding a radiator for that specific model may be hard. You might consider just looking for a close match for another compact tractor. I searched " tractor radiator" on Ebay and found this . Kubota GR 21 Radiator | eBay . Might contact this guy and see if he can give you the dimensions..... it could work.?.
   / D2350FD MITSUBISHI #3
Can it be recored? I can supply the hoses.
   / D2350FD MITSUBISHI #4
Another thought.
If you locate a size that can fit and it is COPPER based you can always relocate the openings as copper rads readily accept soldering techniques.
Any good rad shop will do that for you but it could also be a DIY project.
2018 Atlas Copco Pas200HF Diesel Dewatering Pump (A52377)
2018 Atlas Copco...
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
KUBOTA M6800 UTILITY SPECIAL TRACTOR (A51406)
KUBOTA M6800...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
