D2350 Water Pump
   / D2350 Water Pump #1
bigdogmax1
Alexandria, Louisiana
Mitsubishi D2350
I have a Mits. D2350. I'm trying to find out if the readily available water pumps on ebay are the correct ones for my tractor. The only difference I see is that on mine the pully appears to be pressed onto the pump. The pully is a bell shaped kind of unit, and on the front side there are several threaded holes where the plastic fan attaches to. The pumps on Ebay and the pump from a and t rebuilders (Part 02906-an) looks the same as the ones on ebay, all with a flush mount with four holes for studs, no pulley attached. In theory, I would think I could press the pulley off the new and old pumps, and put the old pulley on the new pump. Not sure if anyone has ran into this issue.
   / D2350 Water Pump #2
could you post some pictures of what you are looking at...or a link.
   / D2350 Water Pump
Well upon further inspection is realized that the pulley actually comes off of the water pump, it was just seized onto it! Ordered the pump off of ebay for 98 dollars, and the seller offers a core return so that's always good. Thanks for the reply
TRUCKING INFO (A50775)
200722 (A51247)
200722 (A51247)
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
2013 Infiniti M37 Sedan (A53424)
2013 Infiniti M37...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
