Oil & Fuel D2350 oil type?
   / D2350 oil type? #1
jeff3869
good afternoon everyone. Does anyone know what type and how much oil goes into the gear box? Is there a filter anywhere. I don't see a spin-on filter. Thank you any help is appreciated
   / D2350 oil type? #2
A good fluid to use is regular hy/trans. You can get it at most farmers co-ops.
The filter is a screen tube behind your right foot board covered by a square metal plate. You are probably better off leaving the filter where it is unless you get quite a few shavings when you drain the oil. It's a booger to get lined back up with the suction line when you go to put it back in. Those screens are good at lasting a good while.
There is a fill overflow plug by your left foot. Pour oil in till it comes out of that hole and put the plug back in. It shouldnt hold more than a few gallons.That should do ya.
2024 CFMoto Cforce 600 4x4 ATV (A51694)
2024 CFMoto Cforce...
2008 Ford F350 XL, Diesel Dump Bed w/Spreader Box (A52384)
2008 Ford F350 XL...
2025 CFG Industrial H15R (A50123)
2025 CFG...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
Ryno Worx Sealant Applicator and sealant pots (A52384)
Ryno Worx Sealant...
