D2050 Hydraulic Problem
   / D2050 Hydraulic Problem #1
Zenostone
Howdy all, I have a problem with my 3 pt hitch on a D2050. Here's what happened:
I was going to mulch some leaves with my grooming mower so I lowered the 3 pt hitch to put it on and it stayed down; it would not raise at all.
So, I took the cover (where the lift arms attach) off and drained the fluid. The hydraulic filter was dirty so I cleaned it, cleaned the sump, removed the hydraulic valve and cleaned it as well.
I put everything back together and everything worked great for about 20 minutes. It would raise/lower just fine. Then I lowered it and it stayed down - the difference this time is as I rev the engine it slowly raises. - ugh! I though maybe there was air in the line so I cracked the feed several times but no difference.
I'm at my whits end. Anyone have any suggestions?
Thanks!!
By the way - ya'll are awesome.
   / D2050 Hydraulic Problem #2
The relief valve isn't stuck open by chance?
Don't know where it is, but perhaps a gauge in the circuit would tell you pressure or not in system?
Year: 2010 Make: Cadillac Model: CTS Vehicle Type: Passenger Car Mileage: 159,051 Plate: Body Type: (A51694)
Year: 2010 Make...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
JOHN DEERE 17P LOT IDENTIFIER 212 (A53084)
JOHN DEERE 17P LOT...
LMC LOT IDENTIFIER 131 (A53084)
LMC LOT IDENTIFIER...
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
