D20-6 Drive clutch adjust
   / D20-6 Drive clutch adjust #1
Neil McDiarmid
Can anyone help me with proper procedure for clutch adjustment on a komatsu D20-6 ? Thanks Neil
   / D20-6 Drive clutch adjust #2
HELLO,
THERE'S NOT ACTUALLY A ADJUSTMENT ON THE CLUTCHES. THERE IS A BRAKE BAND ADJUSTMENT ON THE BACK OF THE MACHINE. THERE IS A PLATE ABOVE THE HITCH WITH 4 BOLTS HOLDING IT ON. REMOVE THE PLATE AND THERE WILL BE A ADJUSTMENT COVER ON EACH SIDE WITH TWO 17MM BOLTS IN EACH. THESE COVERS ARE ABOUT 3" LONG. YOU WILL TURN THE ADJUSTMENT CLOCKWISE UNTIL YOU HAVE 7-8" OF "TRAVEL" ON YOUR STEERING LEVERS. IF YOUR STEERING CLUTCHES ARE SLIPPING, YOU PROBABLY EITHER HAVE OIL ON THEM OR THEY ARE WORN TO THE POINT OF NEEDING REPLACEMENT.
LET ME KNOW IF YOU HAVE ANY QUESTIONS OR NEED ANY PARTS.
THANK YOU,
KENT BAUGH EQUIPMENT
2596 FM 250 N.
HUGHES SPRINGS, TX 75656
903-639-2765
UNUSED HURRICANE 7' X 12' CONTAINER (A51248)
UNUSED HURRICANE...
1998 C6500 Chevy, 3126 Cat Engine (A52384)
1998 C6500 Chevy...
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
2020 Chevrolet Tahoe SUV (A51694)
2020 Chevrolet...
