D1600 manual needed
   / D1600 manual needed #1
Jeremy_R
I have a d1600 that has developed an hydro leak that has leaked on the brakes on the right side. I having a hard time finding a parts and a repair manual. The one link I found has no more copies and wont be getting any more. also trying to get oil capacity specs. for the engine and transmission.
   / D1600 manual needed #2
Jeremy, I can't promise you anything but try Valley Power or Japanese Tractor Repair Dixon, IL for manuals. If your rear case is anything like mine it will hold around 3.5 gallons. There should be a fill level plug on the left side about where your heel is. Hit and miss on the engine oil capacity, maybe 3.8 pints. Trial and error on that.
Oil capacity is around 3 1/2 quarts, Napa oil filter #1390 does not fit. Info on another forum was incorrect. I think its a Napa 1334.
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55301)
UNVERFERTH 330 8...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A55301)
2020 Massey...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
