D1503 starter
   / D1503 starter #1
Texas Bear
Idaho
Tym T330 (manual trans)
New to the group so not up to speed on using it's search features but did not find answer when I searched.
I have a 2007 TYM T330 (manual trans), it has the Kabota D1503 engine, with about 500 hours on it. The starter needs servicing, but thought I would get an extra one while having this one serviced.
Problem: Have to "key bump" starter 1-15 times before it engages and starts tractor. External circuits check good. You can feel solenoid "kick" in when key is turned. I'm guessing brushes or armature problem.
Question: Does anyone know which aftermarket starter will work for this engine? Don't want to spend $450 for an extra one while having this one serviced.
2013 FREIGHTLINER M2 ROUSTABOUT TRUCK (A52472)
2013 FREIGHTLINER...
2016 Sure-Trac 20 Ton Pintle Trailer, VIN # 5JW2U2522G1121114 (A51572)
2016 Sure-Trac 20...
2012 Acura TL Sedan (A51694)
2012 Acura TL...
THE HANDLER II MIXER UNIT (A52472)
THE HANDLER II...
2024 CATERPILLAR 255 SKID STEER (A51246)
2024 CATERPILLAR...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52748)
2003 International...
