cylinders
   / cylinders #1
Lea
Fort Frances Ontario
john Deere model M kabota 2320 TLB
Does anyone have a good source of hydraulic cylinders, I need a couple of single acting cylinders with 6 to 10 inches of travel, all I can find are dual acting and they are too pricey for my project
Thanks in advance
Lea
   / cylinders #4
Plow turn cylinders may work for you and they are usually less than $60. You did not say what bore size you need. CJ
   / cylinders #5
I heard that dual acting cylinders CAN be made into single acting cylinders. The rod port side is simply vented with a proper fitting to let air in & out. Call a hydraulic shop to confirm.
   / cylinders #6
Yea, if you are still looking, what diameter do you need?
Snowplow cylinders come in 8" and 10" lengths, but are 1.5 and 2" diameter usually, and just thru-holes for mounting.
I have used DA cylinders with a vent plug in the rod side for SA applications also.
MD ELECTRIC GOLF CART WITH BATTERY CHARGER (A53424)
MD ELECTRIC GOLF...
2005 Nissan Pathfinder SUV (A53424)
2005 Nissan...
Hose Reel (A53424)
Hose Reel (A53424)
2014 Ford F-150 Ext. Cab Pickup Truck (A55788)
2014 Ford F-150...
GOLF CART (A55758)
GOLF CART (A55758)
UNUSED DIGGIT 6'5"-10 DRAWER, 2 CABINET WORK BENCH (A54757)
UNUSED DIGGIT...
