Cylinder specs - Ford 7108 FEL
   / Cylinder specs - Ford 7108 FEL #1
EricinTN
Ford 1720, 2WD
Can anyone give me the specs for the bucket cylinder on a Ford 7108 front end loader?
I was able to successfully get the 2 lift cylinders rebuilt, and they're solid, but the bucket cylinders are just plain wore out (scored, etc), and still leak way too much fluid.
My local dealer is listing a replacement cylinder at just over $300 each, but I was sorta hoping to find something surplus that might work.
   / Cylinder specs - Ford 7108 FEL #2
That price for new cylinders from the dealer that are guaranteed to bolt on and not give a problem? You may get real lucky with an aftermarket cylinder, but you need your measurements. Bore, stroke, pin size and style, pin center to center closed and opened, port size, style, and angle. There's a lot to consider. You may find a cylinder close if you can live with a little more/less travel or power.
2012 Chevrolet Traverse SUV (A51694)
2012 Chevrolet...
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
PAIR OF FILING CABINETS (A53843)
PAIR OF FILING...
1969 Ford Continental (A51694)
1969 Ford...
(5) 5' X 20' X 3/8" STEEL PLATES (A51248)
(5) 5' X 20' X...
