Cyl. force
   / Cyl. force #1
Hooked_on_HP
Veteran Member
Coal City IL
Ford 1900 FWD Kubota F2100E
How much force will a 3"dia. cly. apply with 2200 psi going into it.
Bill
   / Cyl. force
Thanks Kenny that helps a lot
Bill
   / Cyl. force #5
Bill
Here you go...I put in some other numbers too, hope they fit....7.775 tons
   / Cyl. force
I am building a dump trailer. The cyl. will be pushing up at a 10deg. angle at the start of the lift. With a 3" cyl. and 2200psi will I only be able to lift 2700 lbs.
Bill
   / Cyl. force #7
Go to Surplus Hydraulics, and select tech help, select calculators, select force and speed. and use the the calculations on the right side, which has a place for angle.
Max force is at 90 degrees. Maybe you want to use 80 degrees instead of 10.
0 degrees and 180 degrees, have 0 force, any other degree will have some force and build up to the max at 90 degrees. I believe this is correct.
Draw us a diagram of your cyl to lift point.
   / Cyl. force
Why would I want to use 80deg instead of 10. The cyl. is 10deg up from horizontal.
   / Cyl. force #9
Everything looks great, like i knew it would. May I just say something to give you more to think about. If your like me I should said, sleep on.
I would put kickers between the two beams on each side of the cyl. far enough apart to give you room to pull the pin. And one in the center on the last set of beams.
28013 (A50322)
28013 (A50322)
2017 Freightliner M2 106 T/A 4,000 Gallon Water Truck (A51692)
2017 Freightliner...
2010 L3V Electric cart (A51694)
2010 L3V Electric...
2016 Chevrolet Colorado Pickup Truck (A51692)
2016 Chevrolet...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2018 Ford F-250 4x4 Pickup Truck (A51692)
2018 Ford F-250...
