CX2510HST power beyond connection
   / CX2510HST power beyond connection #1
kestertr
Kioti CX2510HST
I am able to find out how to connect to every type of tractor out there but this one. I ordered a universal spool kit for it with a third member kit to add to my tractor and I know my tractor has power beyond, but I can't find any instruction anywhere on how you connect anything to it. Has anyone worked on Kioti CX2510HST and might know this and if so, please help me.
Thank you
   / CX2510HST power beyond connection #2
Assuming you have a loader....look at your loader valve.
One port should be a PB coming off the loader and going back to the tractor somewhere or even a manifold block.
The power beyond off the loader is likely feeding the 3ph.
There should also be a return or tank port on the loader valve.
Those are the only two you need to be concerned with to attach a 3rd valve.
Now if it's a cast body manual lever valve you need both PB off the loader and return as well as the 3rd valve needs to be a PB capable valve itself.
If it's the electric solenoid type....those usually don't require PB. In which case you supply it from the loader PB, and return it to wherever the loader PB originally went to.
So start with a few simple questions.
Does your tractor have a loader?
If so....how many hoses connected to the loader valve?
What type of 3rd function did you get?
Perhaps a link or make/model of the 3rd kit?
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
2014 FORD E-350 11 PASSENGER VAN (A52472)
2014 FORD E-350 11...
2018 HINO 268  NON CDL 26FT BOX TRUCK (A52576)
2018 HINO 268 NON...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
2017 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2017 PETERBILT 567...
2013 INTERNATIONAL SA615 ROUSTABOUT (INOPERABLE) (A52472)
2013 INTERNATIONAL...
