CX2510 50 hour fluid change filters
   / CX2510 50 hour fluid change filters #1
iptman
Northern VA
Scag Tiger Cat, 61", Kioti CX2510
A couple weeks ago I was down a couple hours away picking up some bees for my bee yard and passed right by the Kioti dealer down there. I stopped in and decided to see if they had all the filters for the 50 hour service. It took the guy about 20 minutes of looking on the Kioti parts website but eventually he picked the filters off the shelf and plopped them down on the counter. Today I was in my local service and parts department and for curiosity's sake asked them if they had the filters in stock. It also took him a bit to pull up the part numbers but eventually he put 4 filters on the counter and then in a box. Not being one to have someone take the time to look up part numbers and pull parts and not buy them I asked how much I owed him for the filters and he said don't worry about it and gave them to me for free. Good deal certainly but my goal of finding out the delta between the two parts shops went out the window. Got the filters home and the only one that's the same is the fuel filter and one of the filters the guy today gave me is a Bosch filter, not Kioti. Anyone know which (if either) set is right? The fuel filter seems to be right and I should be able to see the part number on the engine oil filter tomorrow but the hydraulic and hydrostat filters I don't think I can see the part numbers with them installed on the tractor.
   / CX2510 50 hour fluid change filters #2
If it's your first filter change you may not see a part number on the original filters. I don't know about Kioti but Kubota paints them at the factory.
Well the ones on the right are the same size as on the tractor now.
   / CX2510 50 hour fluid change filters #4
Gee, it looks like they got it wrong on all counts. I recently did the fifty hour change on my Kubota. Prior to going to the dealer I went to the Kubota website for the parts breakdown for my tractor. There I found the original part number for the required filters. I noted the part numbers and requested the filters by part number from my dealer. All were perfect fits for the filters they replaced. I've not shopped for any after market filters. I'll protect my warranty by sticking with genuine Kubota filters and fluids.
   / CX2510 50 hour fluid change filters #5
The set on the right appear to be same I replaced at my 50hr. I believe our tractors share the same engine, but I'm not sure about yours having a 2 spd HST as to my 3 spd. Maybe an internal difference, but same external filters?
Patrick
   / CX2510 50 hour fluid change filters #6
If you choose not to drain your hydro fluid with the 50 hr filter change. Double check the drain plug is tight. I serviced two different CK3510H recently and on both tractor's the drain plug was just finger tight.
   / CX2510 50 hour fluid change filters #7
Whaaaa...?
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
1999 Freightliner Service Truck (A50514)
1999 Freightliner...
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
71056 (A49346)
71056 (A49346)
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52128)
2007 Freightliner...
JB DEMOLITION SHEARS (A51244)
JB DEMOLITION...
