stuckmotor
Super Member
- Joined
- Sep 23, 2009
- Messages
- 5,292
- Location
- Lower Up State S.C.
- Tractor
- AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
Every so often, I read that, after starting a cut, it's possible to turn off the acetylene and continue cutting using only oxygen. This is usually stated a part of an explanation that a torch burns metal instead of melting it. Has anyone here done this? Was the cut as good as if the acetylene had been on. Did the oxygen alone produce as much heat and distortion as both gasses would have? I'm tying to find out whether, the claim is true, and whether this is a practical method of cutting.
