Cutting/trenching ice
   / Cutting/trenching ice #1
KennedyDiesel
Veteran Member
Central WI
We have a project coming that involves laying out several miles of PVC tubing in a lake. The plan is to launch in winter so that placement is precise. The issue is how to cut through 10-12" of ice quickly and efficiently?
We'll want about a 3" minimum width so a stump grinder is likely out. My thought was to simply build a wheel and teeth and use a brush hog gear box to spin it from my 540 rear. I have seen ratios of 1:1.47 in the Northern too listings so I assume 540 becomes 800 with this setup?
Length of runs may approach 2,000' and total will approach 22,000'
Do I counter rotate to keep the blade in, or forward rotate to help motivate the tractor? I would need to rig down pressure to keep the wheel in the ice if I went to forward rotation.
   / Cutting/trenching ice #4
Ken.. I would think a round blade would bind alot,,, thats a very long run..if you were to run off course just a little and have to adjust,,Well kinda like a circular saw pinchs in a piece of 2by4 if you try to streighten out a cut,,,
How about a hyd. chain saw ??? this way you could mount it offset on some sort of setup off your 3pt... ???
   / Cutting/trenching ice #5
I would jerry rig some kind of 3pt attachment with two chain saws on the end of it. Zip tie the throttle on, lower the 3 pt till the 20" bars cut through the ice then take off in what ever slow gear you have to.
You could do this with a very light weight fwd tractor.
I have a 4' asphalt cutter wheel for my bobcat, but it weighs 12000 lbs total.
   / Cutting/trenching ice #6
i have an old 1to1 gear box off a cotton stripper. It runs a wheel with tiller teeth and cuts an 8 inch trench andabout 4 inches wide. It also piles the soil to one side.
Ill get a few pics of it when my wife gets home.
   / Cutting/trenching ice #7
If you use a chain saw remember to modify the chain.:D
   / Cutting/trenching ice #9
Ditch Witch makes an "Earth Saw" for their trenchers. Basically a carbide toothed wheel capable of cutting through soft stone or frozen ground. Since you're obviously in an area that experiences some pretty serious frost conditions, you can probably rent a machine equipped with the saw installed.
   / Cutting/trenching ice #10
Radical different approach - dual mounted, adjustable width, high pressure water jet cutters. If they can cut through steel, ice should be a breeze.
3.37 acres 6402 E Interstate 20, Odessa, TX (A45333)
3.37 acres 6402 E...
Towable Message Board (A44571)
Towable Message...
2004 Ford Explorer Sport Trac SLT Crew Cab Pickup Truck (A42744)
2004 Ford Explorer...
Miller Welder (A44502)
2014 UTILITY 53X102 DRY VAN TRAILER (A43004)
2014 UTILITY...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A43003)
2018 VOLVO VNL...
