MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 66,954
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Just take a piece of twine or fishing line and attach it to a tennis ball. You can drill through a tennis ball and stick the line through it, or use the duct tape method. If you need more weight, you can add some water to the tennis ball. Throw the ball up over the highest part of the tree that you can. If you can't throw that high, use a tennis racket and whack it or get some kid with a good arm(but keep him away from under the tree). After the line comes down the other side, use it to pull up a heavier string and then a rope.
Attach a chain to the end of the cable. On the other end of the chain attach a clevis. Make sure the clevis is large enough for the end of the cable and chain to slip through. Pull the clevis up and over with the rope. Pull it all the way back down to the ground. Slip the other end of the cable through the clevis and then pull it until the chain tightens around the trunk. This is where a really long cable comes in handy. The longer the cable, the higher up the tree you can get and the more leverage you can get with your pull vehicle. Anyway, I've had good success with this and didn't have to climb the tree. Remember, if it looks too dangerous, it probably is. Your brain is tuned to catch these details(at least most people's are). If you detect this danger, call a professional. It is money well spent.
