Cutting Trails / Clearing Brush
   / Cutting Trails / Clearing Brush #1
Climber
Bronze Member
Pennsylvania
Kubota B7300HSD
Hi Folks,
I have about 10 or so acres of woods. A lot of it is pretty thick with brush, and very nasty briars. There are the usual rocks, fallen trees, etc. I would like to put some hiking trails through the woods, and to thin out some of the areas of dense brush, if possible. Can any one tell me the best way to do this? I am open to all suggestions, including those that do not involve a tractor. /w3tcompact/icons/shocked.gif
Also, If I do not own the right tractor/implement/tool, I am open to the possibility of renting it.
Thanks,
--Chris
   / Cutting Trails / Clearing Brush #2
Chris,
I had a similar situation last spring with the five acres of woodland we purchased in east central Missouri. I rented a walk behind brush hog manufactured by Bachtold Brothers <A target="_blank" HREF=http://www.bachtoldbros.com>http://www.bachtoldbros.com</A> I was amazed at what I could accomplish in one day. It would cut about a 24 inch path through anything up to and including two inch saplings /w3tcompact/icons/shocked.gif. A picture of what I used is on their website under the "commercial products" catagory, and the machine itself was very similar to what they call their "Champion". Believe it or not, I have also used an old 12HP riding lawn mower with the cutting deck raised up as high as it would go to maintain the trails I had cut with the Bachtold. The lawn tractor would actually cut stuff up to one inch if I took it slow. Of course now that I have my beloved Kobi, (B7500HST), I will be getting a rotary cutter before things start popping up this spring /w3tcompact/icons/smile.gif
   / Cutting Trails / Clearing Brush #3
I'd buy a 4' heavy duty pull behind mower and be done with it. In an hour you could make all the trails you wanted. You can go forward, back in, whatever with it. I have the push behind mower like was mentioned to use and that's too much work in my opinion. I completely rebuilt the one that I have and I haven't used it since then. Just too easy and fast to use a rotary cutter for anything that needs to be done. With the 4600 there aren't too many places I can't get to.
   / Cutting Trails / Clearing Brush #4
Any hills to deal with?
A friend of mine uses a B7100 with just a back blade to cut trails. He's made some mods to the blade, and also has T&T with hydraulics on both lower arms. This allows him to back into a hillside and make some pretty radical cuts. It's amazing what he can do with it. I think he's done a hundred miles of trails at the nearby open space preserves.
   / Cutting Trails / Clearing Brush #5
I have 22 acres in south west Michigan that is very similar to your property. When we first moved here I couldn't even walk through the property, it was so full of briars and brush. I decided to buy a DR brush mower and I have never regretted it. I bought the 10.5 hp model and it literally chews up the brush and saplings up to an inch thick. I have made several trails and I can mow on extremely steep banks like those around my pond. You could never do that with a tractor mounted mower. The DR brush mower has the advantage of being able to quickly go around small trees and nursery stock that you want to keep and then destroy the stuff that you don't. You simply won't have that ability with a tractor. I own a B72oo with a 4' rotory cutter, but I don't use it for the trails. The DR simply works better in this area.
Van
   / Cutting Trails / Clearing Brush #6
Climber, will you use the trails for anything else, and how wide? Maybe to get the truck to the back of your place.... As most have said I would go with a heavy duty cutter and backblade, these two should take care of most anything you need. Other implements may do somethings a little better or easier but these two are the basic and usually the first two any new land owner gets. If after you give these two a try, and find you need something bigger, you will know for sure what you need; and can then beg, buy or rent what you need. Or even step up and hire some heavy equipment for a day to clean up what is left that needs cleanning up... But the cutter and blade you will almost always use....
   / Cutting Trails / Clearing Brush #7
Climber -
I started doing the same thing on my wooded lot in Vermont. The trails started with a Craftsman Garden Tractor with a 50" mowing deck, then I added ag tires to it to help on the hilly land. Worked pretty well, but I was trashing the mower on the tractor (busted a pulleys, trashed some blades, etc).
When I bought my NH TC33D, the Craftsman got a rest. I'm using a 5 ft brush mower with good success. Not as manueverable as the Craftsman, so I've had to take some kinks out of the trails, and cut down a few trees I couldn't fit between any longer, but it goes much more quickly with this set up. The only drawback to mowing is having to go back with the box blade to tear out all the sapling stumps (I want to use the trails for cross country skiing, and the stumps would tear up the ski bottoms unless we got a LOT of snow)
Also check out <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=projects&Number=40707&page=&view=&sb=&o=&vc=1> this thread</A> for some info on a 3 pt hitch tree puller a member built. Sounds interesting and has the advantage of pulling the saplings up by the roots, so you don't have the stumps to contend with. I haven't tried it myself, but hope to make one in the near future.
John
Nope. No hills to deal with. Your suggestion has the advantage of using an implement I already own, but I was hoping to keep the trails narrower than 5ft. (I currently don't foresee the need to get my tractor to the back of the property, but then again, that may change someday).
I may give this approach a shot, and see how it goes.
Thanks,
--Chris
Jag,
I am currently only planning to use the trails for hiking. So a trail 2 or 3 ft wide is plenty for my needs. I don't currently need to get my truck or tractor top the back, but I may need to someday, if I want to pull trees out for firewood.
Thanks,
--Chris
FAKE (A52472)
FAKE (A52472)
2006 VOLVO L110E (A52472)
2006 VOLVO L110E...
3 PHASE SEPARATOR (A52472)
3 PHASE SEPARATOR...
1999 KENWORTH W900 TANDEM AXLE SLEEPER (A52576)
1999 KENWORTH W900...
