Cutting the last row of grass
   / Cutting the last row of grass #1
Flyin2low
Maryville
1976 IH 484
What is the best technique to cut the last row ( when it is narrower than the normal row) with a right side discharge mower deck.? :cool2:
(1) favor the left side of the deck
(2) center up on it
(3) favor the right side of the deck
   / Cutting the last row of grass #2
(2) center up on it
I didn't know mowing was so technical. Me? Right down the middle.
MoKelly
   / Cutting the last row of grass #3
Ha,ha - - my God, you got that right, McKelly. I favor the right side of the deck because if I go center or left it will put the deck out in the pucker grass. And we all know what's out there - big rocks, discarded what-evers, sprinklers that were not properly stored last fall - things that will rattle around under the deck before being discharged.
   / Cutting the last row of grass #4
If there's no risk of hitting anything like mentioned above, then the center is the best choice. It gets you at least two blades to work on reducing the clippings in size before they exit the deck, and less of, or no tires to flatten the uncut grass down before entering the cutting chamber.
   / Cutting the last row of grass #5
If you like using your mower, you should cut it crossways.
More seat time.
Bruce
   / Cutting the last row of grass #6
Backwards.
   / Cutting the last row of grass #7
Fastest pass to get barn and hard earned cold beverage.
   / Cutting the last row of grass #8
Leave it until tomorrow, it will give you something to look forward to.
   / Cutting the last row of grass #9
Cut the last row first, then you'll be done and have saved a lot of time.
2014 Nissan Juke SUV (A51694)
2014 Nissan Juke...
1993 Ford F-150 Pickup Truck (A52377)
1993 Ford F-150...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A53473)
2012 NEW HOLLAND...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2017 Wanco WSDT Towable Compact Radar-Speed Trailer (A52377)
2017 Wanco WSDT...
2008 Nissan Sentra Sedan (A51694)
2008 Nissan Sentra...
