Cutting techniques...
   / Cutting techniques... #1
Grant1994
Okay so I still have many trees to cut on my property as well as on friends property's and my neighbors. I was wondering if you all can give your different techniques for bucking a tree that is flat on the ground because today I kept getting pinched as well as hitting the ground. I use wedges to free the pinches but these trees are to big to lift by hand to get something underneath them for bracing. Any advice?
   / Cutting techniques... #2
There are 2 things you need to understand.
1st, NEVER let the saw touch the dirt. It will dull it instantally.
2nd, you have to know what part of the log is in tension and what part is in compression.
If the bottom of the log is in tension and top in compression, and you cut top down, you will pinch, as you have figured out.
IF there is clearence underneath, cut from the top JUST unitl you start to see the gap close up. STOP. Pull out and undercut.
The reverse is true it the top is in tension and bottom is in compression.
Just be MINDFUL at ALL times when cutting. Know WHERE things are going to move/settle once you make the cut.
And honestly, it is very difficult cutting large trees without some equipment, like a tractor/loader. Because what we do, in a case like yours where you cant cut all the way through because of dirt/pinching: cut as much as you can until the gap closes or you have to stop to stay out of dirt, then move on to the next cut, and so on. ONCE you have all the cuts made, use the tractor to "roll" the log over.
And if you dont have equipment, you can use a peavy or cant hook. you can google both to see what I am talking about. But they dont work well on really LARGE logs.
And a final tip, always start with the smallest part of the tree. NEVER start cutting at the base first. Cut up all the limbs and get the brush out of the way. When you get ALL the limbs cut that you possibly can, then start on the base. Reasons for this are:
1. Limbs in the air are easy to cut as opposed to on the ground.
2. It makes the base/trunk less likely to move when cutting it, due to limbs sticking out and up in the air.
3. It makes the base easier to roll IF you cant cut all the way through, as described above.
I know all that is alot to take in. IF you are unsure about anything, or have more specific questions, please just ask. A chainsaw is a VERY dangerous tool in the hands of an in-experienced operator. And that is NOT meant to insult you. It is meant to encourage you to PLEASE ask if you have ANY doubts at all about what you are doing. I would rather you ask a "stupid" question, rather than just try something and end up getting hurt.:thumbsup:
   / Cutting techniques... #4
Great response, LD1!!!
Two more reasons to start w branches and limbs working smaller to larger (if I may he so bold, not knowing half as much as you):
- you reduce weight and bulk from one end, sometimes reducing binding if trunk is not flat on the ground.
- you remove obstructions/ trip hazards. Stop often and clear the cut stuff from your work area. I once saw a fellow trip and fall while cutting up a large oak branch that fell across the road. You don't want that to be you.
Be safe. Listen to LD1.
   / Cutting techniques... #5
That was a great response! Tryand release as much compression as possible-cutting smaller branches, cutting part way through and moving on to your next cut, if you are not trying to buck for logs, making a V cut to relieve compression can sometimes alow you to finish the cut-and remember, wedges and loaders are your friend.
Will
Thanks for the advice I don't rake insult at all! I will admit I have very little experience I'm trying to learn as much as I can!
   / Cutting techniques... #7
Wow LD1 you nailed it!
I read the whole things and said, yup, did that, yup, that log did roll towards me when I wasnt thinking.. Great stuff and great advise.
I can also add, when working in trees down in the woods leaning into other trees or jammed be very-very careful. When in downed/lodged/jammed trees take away all loose brush and make an escape route before you cut. Have a partner/helper tie off any suspect branches/logs or use the tractor to support / countersupport and push the way you want it to go.
If it looks like its dangerous, it is.. dont take chances, get help or step back and figure out a safer way.
   / Cutting techniques... #8
LD1 is dead on. The only thing that I would add is: keep your chain sharp, don't force the saw, keep the RPM up and let the saw do the work.:thumbsup:
Jim
   / Cutting techniques... #9
I just want to add my thumbs up to LD1's post too. Well written, great advice sir.
   / Cutting techniques... #10
I agree that mosst of his advice is good. #1 tho is totally wrong. Touching dirt (unless it is rocky) does NOT "instantly dull the chain". It will shorten the time before you have to resharp but with care you can hit dirt and still keep cutting for a long time.
Technique that has worked for me doing 6+ cords/yr for over 30 years.
1. examine the log. Very rarely is then never a spot where it is clear of dirt somewhere, usually several places. If there is one, cut rounds almost all the way throuigh until you reach one and then roll the log to complete the cuts.
2. If you will have to cut into dirt: Cut 3 or more rounds down to almosst the dirt INSERT wedge if the kerf starts to close or even before if you know it will close.
3. If cutting dirt is unavoidable, complete the last cut: watch and feel as the saw nears the bottom and then start 'babying' the throttle to keep the chain barely turning. Roll cut section of log and finish prior cuts.
4. As last resort, carry and extra loop or two so you can swap out to finish the days work. I hate 'touching up' a chain in the field. Swapping them is much faster.
Harry K
ATTENTION! PLEASE READ (A50120)
ATTENTION! PLEASE...
2008 Isuzu NPR-HD Landscape Dump Truck (A50323)
2008 Isuzu NPR-HD...
2006 SCHWING P-88 PORTABLE CONCRETE MIXER (A51243)
2006 SCHWING P-88...
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
2023 JOHN DEERE 135G EXCAVATOR (A51242)
2023 JOHN DEERE...
HYDRAULIC PUMP FOR JOHN DEERE 544 WHEEL LOADER (A51244)
HYDRAULIC PUMP FOR...
