cutting speed and gear selection while bush hogging..
   / cutting speed and gear selection while bush hogging.. #1
calfal
lake charles,la.
kubota l275 power king 14/24 kioti ck27
where I cut some of the ground is kinda rough .. I cut in low gear /4th this is pretty slow2.88 mph.. in the smoother parts I can high 1st 4.09 mph..what do you guys cut at.. this is a kioti ck27 with a 5 ft, modern bush hog..no rocks here.. I have a suspension seat,, thanks c falcon
   / cutting speed and gear selection while bush hogging.. #2
You really have to work out the gearing for your particular tractor and terrain. When I had a tractor with a standard transmission I'd set the tractor engine speed where I wanted it to run and set the gearing that worked. Sometimes the ride was kind of rough. My new tractor is an HST and it's really cool. I can set the engine at PTO rpm, put the transmission into the middle gear and vary my speed with the forward pedal. I can back off for rough areas and never change PTO speed.
   / cutting speed and gear selection while bush hogging.. #3
I go as fast as I can without bogging, getting bounced out of the seat, or missing grass. At the moment I can be in high range turtle in the HST tractor, but after rain it can get down to low range turtle. Some of the rougher country is low turtle all the time.
Geared tractor is low range second so far. But I haven't done much mowing with it yet and it was on the side of a hill.
Ford Super Duty Truck Bed (A47384)
Ford Super Duty...
Killbros 260 Seed Conveyor (A52748)
Killbros 260 Seed...
2 Axle Trailer (A50774)
2 Axle Trailer...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
Bobcat Skidloader PHD (A50774)
Bobcat Skidloader...
Deere 317G (A50120)
Deere 317G (A50120)
