Cutting plexiglass
   / Cutting plexiglass #1
fivestring
Veteran Member
South Central NC, USofA
Iseki TU1700f
I want to make some blade guards for jigs.
Can plexiglass be cut with a jig saw?
If so, which blade is best for a smooth cut?
Any tricks to keep it from cracking?
Thanks, Gary.
   / Cutting plexiglass #2
I have cut Lexan with a jig saw. I think it is pretty simular material. No problem with cracking on that.
   / Cutting plexiglass #3
The coupla times I've tried, the blade heats up and melts the plexi behind the cut and all I ended up with was a mess. I had much better luck scoring and snapping. They sell cheap plexi cutters everywhere to do the scoring. Even with thicker stuff - you just have to make repeat scores - making the score deeper - which is real easy to do after the first one..
   / Cutting plexiglass #4
The best blade is a table saw with a carbide tooth blade with lots of teeth. Of course, that will only work for straight cuts. For curves you can use a jig saw with a blade that produces a kerf (not a hollow ground blade) so that the sides of the blade don't rub across the plexiglass and cause heat. The reason for cracking is vibration - the plastic needs to be firmly supported.
I've had good luck cutting curves using a router with a template. Use a small diameter (~1/4") straight edge carbide bit, and go slow.
Once it is cut, use a file or sander to smooth the edges. Professional shops will polish the edges using a muslin wheel charged with rubbing compound. The trick with the muslin wheel is to get the edge hot enough to melt a bit and get smoothed out, but not burn. It takes a few tries to get the hang of it. At home, I've had good success with sandpaper, going through 80 - 100 - 150 - 220 grits, and then using a propane torch to flash the edges. Again, you must balance between heating it enough to polish the edges and burning the edges. Practice on scraps.
   / Cutting plexiglass #5
Cut it using a router. Smooth cut with no chipping.
   / Cutting plexiglass #6
As already mentioned, the plastic melting and sticking to the blade is an issue.
I've never tried the router though! Might have to give that a go.
   / Cutting plexiglass #8
Gary,
Depends a bit on the thickness that you are trying to cut. If it is thin stuff ( 1/8 in or less ), then I'd probably try to just score it and snap - ofcourse that doesn't work too well for curves, especially compound curves.
I've used the jigsaw on thicker stuff or to do curves. Two things to do to minimize cracks. Be sure to leave the protective film on ( or use masking tape along cut line ). Make sure the tape or film covers the full width of the shoe to keep from scratching the surface. The other thing is to place the material on a sacrificial surface (plywood/osb/???) while cutting. For thin material, you could actually sandwich the plexi between two sacrificial layers to minimize flex around the cut.
I think Lexan is easier to cut cleanly than plexi since it is more crack-resistant. Polycarbonate would be better yet, but is more $$$.
Sanding and torching as mentioned above is nice to clean up your cut edges. The heat helps to 'weld' any micro cracks that might be found along the edge.
   / Cutting plexiglass #9
I haven't used a spiral bit. I've used a straight bit or a "bullnose" bit. The bullnose gives you a slightly radiused cut so you don't have square edges that can chip.
   / Cutting plexiglass #10
I've used many methods, but I like the band saw the best. It's long blade and single direction reduce heat buildup and cracking, respectively.
Sam
MISSION 4X3X14 CENTRIFUGAL PUMP (A53843)
MISSION 4X3X14...
2025 Unused LandHero LDH-T460XX Mini Skid Steer (A52377)
2025 Unused...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
11 10 FOOT BY 5 FOOT LIVESTOCK PANELS (A53843)
11 10 FOOT BY 5...
2014 10ft T/A Dump Trailer (A51691)
2014 10ft T/A Dump...
2017 Hino 268 20ft Flatbed Truck (A52377)
2017 Hino 268 20ft...
