cutting metal
   / cutting metal #1
mit
which is best to cut metal a cutting torch or a hack saw?
   / cutting metal #2
Is this a joke question?
   / cutting metal #3
Depends on the metal? By hacksaw, did you mean power hacksaw?
   / cutting metal #4
A hand held hacksaw won't hold a candle to a torch, unless the torch is out of fuel or oxygen.
I use a hand held portaband saw almost as much as my torch. Blades are reasonable and one will cut most metals I deal with when fabricating things.
David from jax
   / cutting metal #5
I asked what type of metal because a cutting torch works best on ferris metal. Heat causes problems with stainless hardening and then we have Aluminum....
   / cutting metal #6
A hacksaw if you want a clean cut and hacksaws come in handy if you falling behind in your exercise regiment.... also a hacksaw won't catch flamable materials on fire like field, barn, house, self...etc.
   / cutting metal #7
Mit
Not enough information. This is definitely a case of the right tool for the job. I use a metal chop saw with abrasive wheel for most of my steel stock cutting. A metal bandsaw would also work well for this with a neater cut, but typically slower. For thin sheet steel, I prefer a plasma cutter as it leaves a nice clean cut. For thicker steel, a torch is probably better but the heat can lead to distortions and the cut requires more cleanup. As mentioned stainless and aluminum are different animals. For aluminum stock, I use my compound mitre saw with a high tooth count carbide blade(cuts a lot like hardwood) or the sawsall with metal blade. Stainless is probably best left to the bandsaw. For me, a hacksaw is only as a last resort where nothing else would fit, or out somewhere with no power source but my tired old elbow... I would turn to my battery powered sawsall with metal blade(and often do) long before I dug out the hacksaw...
   / cutting metal #8
Neither. A plasma cutter is 'best to cut metal'.
JayC
   / cutting metal #9
effective metal cutting instruments
Plasma cutter
O/A torch
15" cuttoff saw/cold saw
4.5" grinder
recip saw
bandsaw/portaband/horzontal bandsaw
shear
nibbler
hacksaw
   / cutting metal #10
I bought a metal cutting tool recently that just blows me away every time I use it. It is a Steelmax metal cutting circular saw. I got it on eBay, thinking it might be OK but not really expecting much. When I tried it out, I couldn't believe how well it worked. It will rip through a piece of 3X1/4 channel almost like a regular circular saw cuts a 2X4, and the cut is clean, burr free, and cool to the touch as soon as you finish. It will cut up to 5/16 thickness, and up to 2.5 inch depth (like pipe or tubing). Not sure how long the blade will last, and they are a little pricy (about $40) but I think well worth it if they last a decent time. Several companies make a saw like this, and they even have one from Harbor Freight that comes with a blade for $99. Some of you may want to check these things out.
1999 Budweiser Beverage Trailer (A51572)
1999 Budweiser...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2011 Toyota RAV4 4x4 SUV (A51694)
2011 Toyota RAV4...
Ryobi Compound Miter Saw (A51573)
Ryobi Compound...
2025 New/Unused Wolverine 32in Hydraulic Backhoe Excavator (A51573)
2025 New/Unused...
7099 (A51573)
7099 (A51573)
