cutting hay
/ cutting hay #21
Ease of attachment to tractor is a big plus for me.
/ cutting hay #22
Do you realize how fast a tractor would have to go to cut 5 acres per hour with a 4 ft cutter?? 12+ MPH which is way to fast for my Fireant/gopher mound infested ground but you ground is probably smoother.
I would have to replace my tractor after one season running 12mph across my pastures..
/ cutting hay #23
i have never used a caddy but i have owned several pull conditioners.i would much rather use 3 pt cutters .for your kubota tractor to handle the cutter easier be sure to set the tires all the way out front and back,use front weights and rear wheel weights.makes a big difference.
The biggest issues I had with the 3pt mount was: bending/breaking sway link pins and threaded adjustment bolts on the lower lift arms for the 3pt and it was a real PITA to hook up and get adjusted outward of the rear tire.
And I had a small Kuhn with a 5.5' cut.
I'd be lookin' for a caddy mount with a 9'-10' mower - seriously - especially with a 5,000lb tractor!
AKfish
/ cutting hay #24
i do not understand right now i have a 9 foot comer bar mower and a 10 foot vicon both 3 pt and like them.i run the 10 foot on a 60 pto horsepower tractor as fast as you can sit on it.the 9 foot ,i usually run it on the 75 pto tractor.sometimes i put it on the 45 pto horsrepower mahindra.they are a little aggravating to hook up but when you lay the ground off like we do they are faster than a pull type.
/ cutting hay #25
No doubt... I could always go faster with a 3pt mount versus the pull-type! I could really go faster with either type - than good sense and field conditions - would allow... When I said that the 3pt mount was a PITA - once you got it set up - you had to continously monitor the sway links. If they worked loose (even double nutted) and they always did - you'd have cutter bar "slop" and it would wander; especially if you tried to add any extra speed. And once it was even a bit loose - those pins and adjustment bolts would take a beating.
My pull-type; once it's set up on the tractor - it's mow until you're low on fuel. 'Cause it's pretty much care-free beyond that! :thumbsup:
AKfish
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
(125) PALLET OF UNUSED SAFETY CONES (A60432)
(125) PALLET OF...
UNUSED SDLANCH IRET13 ELECTRIC TRICYCLE (A60430)
UNUSED SDLANCH...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2012 Chaparral boat with trailer (A59231)
2012 Chaparral...
43024 (A59228)
43024 (A59228)
