Cutting grass vrs. mulching
   / Cutting grass vrs. mulching #1
Keef
Bronze Member
Pennyslvania
John Deere LA135
Ok, if you have small property, you can bag the grass. But once you get a larger piece of land, do you guys usually cut the grass out of the discharge area or do you mulch? I was told mulching is better for the grass, but some have said by cutting the grass and discharging it, it helps the grass not to burn. What are your thoughts on this topic?
   / Cutting grass vrs. mulching #2
Mulching would be best.:D :D But it may depend on how thick, tall and heavy the grass is.
I do use a mulching mower on my town hand sized lawn.:D :D
   / Cutting grass vrs. mulching #3
I mow a little over an acre and I don't mulch, still occassionally get burns, but that is more due to cutting shorter than I should.
   / Cutting grass vrs. mulching #4
I've been mulching for about 10 years now, first with a 445 and now with a 2305. I try to cut it often enough so that I don't cut more than a third of the grass height, but haven't always managed to do that. I've found that with mulching, I don't see the widrows that I used to get and if I let the grass get too high, i just mow overlapping the previous row to get rid of any grass clumps. In the fall, mulching makes getting rid of the leaves so easy. My dealer recommended that I wait and install the mulching kit in August, but I have found that having it installed all the time has been the best way to go. It does a good job mulching the grass as well as the leaves.
   / Cutting grass vrs. mulching #5
I bag and compost with about 2 ares of mowing I need to do. Best part is I have a big chunk of fresh, high nutrient dirt after a two year wait (compost pile gets created during the first year, moved and turned the following spring, used the following spring/summer).
   / Cutting grass vrs. mulching #6
Grass clippings are great fertilizer, so I mulch them back on the lawn. If I needed the compost heap more, I'd put them in the compost
   / Cutting grass vrs. mulching #7
Charlesaf3 said:
Grass clippings are great fertilizer...
So each blade of grass can dine on the rotting, dismembered corpses of his friends and family as well as his own body parts? You guys are sick! :D
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2020 KENWORTH T680...
TROYBILT TB51BP GAS BACKPACK BLOWER (A51248)
TROYBILT TB51BP...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
