cutting edge bar ?
   / cutting edge bar ? #1
JMA375HH
Bronze Member
Soldotna Alaska
NH TC33DA
Need to find cutting edge bar for my new holland tc33da loader bucket. went to my local dealer and the bar he had was differant bolt hole pattern. anyone know were i could order one from that would bolt rite on. my bucket came pridrilled with 1/2'' holes. spaceing is 2-1/4'' from inside edge then there spaced every 9-1/4 center to center. any help would be great I am wanting to build a tooth bar for my tractor, and want to beable to bolt it on and off. /forums/images/graemlins/confused.gif
   / cutting edge bar ? #2
You should be able to order a replacement cuting edge for the loader bucket
Anoter solution may be to blow holes in some straight weld on cutting edge. This way you could pick a size that will be more robust and maybe make iteasier to make make the thooth bar. You could also design it to slip over the exsisting cutting edge and make some new bolt holes in the bucket for attachment.
Egon /forums/images/graemlins/grin.gif
   / cutting edge bar ? #3
Do you have a 60" HD New Holland bucket? If so, the New Holland cutter bar should bolt right on. When I get a chance, I'll measure the holes in mine. My guess is that your dealer is trying to sell you an after-market cutter bar instead of one directly from New Holland. I'll get you some measurements as soon as the weather allows me to do it. It may be this weekend...
   / cutting edge bar ? #4
NH has two buckets for that machine 60" and 68" part number for cutting edge. 60" is 716426016 68" is 716427016 this should help you get the right one. at least this is all they show in there parts system to that machine
Jim No Need got it worked out with our dealer in the big city. thanks for everyones input to this. /forums/images/graemlins/smile.gif
2016 Kenworth T270 Truck, VIN # 2NKHHM6X1GM110171 (A51572)
2016 Kenworth T270...
2023 JOHN DEERE 8R310 LOT NUMBER 203 (A53084)
2023 JOHN DEERE...
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
378659 (A51573)
378659 (A51573)
DOOSAN G25 GENERATOR (A52472)
DOOSAN G25...
2020 JOHN DEERE 7R210 LOT NUMBER 50 (A53084)
2020 JOHN DEERE...
