Cutting corrugated roofing
   / Cutting corrugated roofing #1
sodamo
Super Star Member
Big Island, HI
LS XR4140H (Mine) BX2380 (wife’s)
Have the opportunity to get some 29 gauge galvalume roofing panels for my carport project.
Challenge is the panels are 12ft and I’m planning on 26 ft , meaning I would need to cut 4 panels 3 times resulting in 16 3ft sections.
What would be best way to make such cuts resulting in nice clean edges that would be exposed? Can I cut all 4 panels together or just individually?
I could just buy 26ft panels, but plus $2/ft more make the galvalume deal attractive.
   / Cutting corrugated roofing #2
I've got that same roof. We cut it using a metal nibbler. I cut them one at a time because our cut end was going to be hidden.
I loved the galvalume so much I have it as my ceiling in my shop too.
   / Cutting corrugated roofing #3
I had to cut all my aluminum roofing with a thin carbide blade on my Skill saw. The cut were fine. I cut four panels at a time.
   / Cutting corrugated roofing #4
I use a thin cut off wheel on a hand grinder. Cut all four at once if you want. Just clamp them so that they do not move while cutting them.
   / Cutting corrugated roofing #5
If you have access to or could rent or borrow a plasma cutter that might work for you. The sheet metal nibbler would probably be a less expensive alternative but I don't think the edges would be quite as nice.
   / Cutting corrugated roofing #6
Probably a metal abrasive blade in a skill saw would give the cleanest cut 1 at a time or clamp them and cut slow so you don't burn the saw motor out.
   / Cutting corrugated roofing #7
I cut it with a woodblade turned backwards in a circular say. Wear hearing protection and eye protection. Clamp it down
   / Cutting corrugated roofing #8
I used the metal abrasive blade in my skilsaw as mentioned above, with the roofing upside down on two by fours to keep from crushing or scratching it.
Thanks guys.
Leaning toward circular saw. I have a nice Rigid worm drive. Just need to decide which blade. Would prefer cutting all 4 at once. Going slow not a problem. Hoping for edge that requires least dressing before painting. One edge would be exposed but might cover with an 90° edge trim. The other edge would most likely be visible inside carport, unless it lands on purlin.
   / Cutting corrugated roofing #10
I turned the four sheets over and cut them all at once from the bottom side. If there were going to be any "raggie stuff" I wanted it to be on the bottom. It turned out good. If you do end up using some kind of blade in your worm drive - use eye protection and a FULL face shield. And a work jacket. I picked tiny, tiny chunks of AL out of my hide for a day or so. A little festered red spot would show up - pick at it with a sharp pointed knife. Dig out a tiny chunk of AL.
Big mistake on my part - I only wore a short sleeve T-shirt. I DID wear safety glasses and a full face shield.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2013 Ford F-550 4x4 Horton Ambulance (A50323)
2013 Ford F-550...
2006 Ford F-550 4x4 Flatbed Truck (A50323)
2006 Ford F-550...
2007 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2007 Ford F-150...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
2015 Z Master Professional 5000 Series 60in Zero Turn Commercial Mower (A50322)
2015 Z Master...
