Cutting an old propane tank
   / Cutting an old propane tank #1
CharlieTR
NE TX
Long LongTrac
I want to build a sand blaster, and I just came across a trailer load of various sized propane tanks for cheap. I want to buy a skinny long one and cut it one third of it off for a sand tank. Anyone know the best way to clean out an old tank, so it can be torched.
   / Cutting an old propane tank #2
Charlie,
Your going to have to make sure the tank is empty to begin with. You will have to remove the main valve and then fill tank with soapy water and rinse. I would also try blowing compressed air in the tank to clear it of residual fumes. At that point you should be able to torch cut the tank. This may take some time to rid tank of strong odor!
   / Cutting an old propane tank #3
I've heard of using dry ice which will displace the propane and leave non-flammable CO2 as it vaporizes. I'd get a lot more detail before I tried it though /forums/images/graemlins/shocked.gif
   / Cutting an old propane tank #4
I've removed the valve and then filled it with water to displace the propane. Still stinks though.
   / Cutting an old propane tank #6
Any of these methods will work. Propane is heavier than air so take the valve off and do any of the above methods. Turn it upside down for a day or two and happy cutting.
   / Cutting an old propane tank #7
The steel of the tank will absorb the ethyl mercaptan
(odorant) right out of the propane. Therefore, even though there is absolutely NO flamable vapors in the tank-- you will still smell the odorant-- forever-- and that is a long time!!
As previously stated--purge, purge, purge first. Fill tank with water-- then drain water out. It's gotta be straight air in the tank now; but it will still stink. Good luck. Don
Thanks guys!
Great info.
I think I will not buy a LP tank and make a sand blaster. I will keep looking and maybe find an old compressor tank. I was willing to risk getting blown up, but not that darn stink forever!
   / Cutting an old propane tank #9
Yeah the blowing up part only lasts a little while /forums/images/graemlins/grin.gif
   / Cutting an old propane tank #10
I converted an old LP tank to an air bottle about 20 yrs ago.
The air in it STILL smells of propane. I cycled air through it for hours and it still smells.
ron
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A52472)
2014 AMERITRAIL...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A52472)
2012 TEX MEX...
2012 Chevrolet Silverado 3500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
2012 John Deere 7280R MFWD Tractor (A53472)
2012 John Deere...
2001 TRIPLE E INDUSTRIES 3-AXLE STEP DECK 48X102 (A52472)
2001 TRIPLE E...
