CUT'S gear change issue HST
   / CUT'S gear change issue HST #1
4720 OWNER
WEBSTER, MN
JD 4720
Talked to a JD mechanic, when he found out i had a 4720 he said to be gingerly changing gears with the left hand handle, the ABC gearing. There is a little fork in there that actually changes the gears to match what speed or power you want. If try to change too energenitically ( sp? translates to using too much armstrong power) the little fork ends can break off. This means the tractor HAS TO BE SPLIT IN HALF to fix. He did not give me a price but i bet it is not cheap. I am not sure if the fwd lever is the same but could be. It was only 2 tractors in 3 years, but just thought i would pass it on.
   / CUT'S gear change issue HST #2
Reminds me of something my flight instructor taught me: You don't "flip" switches, you "position" them....
   / CUT'S gear change issue HST #3
Many thanks for the info. Who would've ever guessed. Certainly will be more careful changing ranges from now on.
Allmand Light Tower (Runs and Works) (A50775)
Allmand Light...
2018 Heartland Recreations (A55758)
2018 Heartland...
DYNAPAC CA250D SMOOTH DRUM ROLLER (A54756)
DYNAPAC CA250D...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
(APPROX.100) UNUSED FUTURE 12' GALVALUME STEEL TIN (A54757)
(APPROX.100)...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
