cut open a propane tank
   / cut open a propane tank #1
ch1ch2
Veteran Member
DFW, TX
IH 584, NH TC33DA, NH TN95A
I was reading a post on moving a propane tank.
Got me to thinking. How could I cut it open and make a fire pit out of the end caps.
   / cut open a propane tank #2
You must make sure all fumes are cleared from the tank or boom.
By cutting torch or cutting wheel the heat would be enough for ignition.
Cutting wheel would leave a cleaner finish.
   / cut open a propane tank #3
I wouldn't do that unless I filled it completely with water first, then drain and cut. I would still be worried about it.
I had an empty 55 gallon barrel that had stuff to make fiberglass out of and was flammable., very flammable. It was old and dried when I got around to it,
I had the bung open and was chiseling the top off but that was so slow, so I started cutting it with the welder or a 4-1/2 grinder if I recall. I don't remember which.
All of a sudden I heard a rumble then a very big woof out of the bung hole. I think I soiled myself. Went back to chiseling.
   / cut open a propane tank #4
They make a great fire pit. I have one that has flames cut into the side using a plasma cutter. I often see them advertised around here for better than $300. Should last a lifetime to.
   / cut open a propane tank #5
Thats what i do too. But stuff for fiberglass (acetal resin ??) is a different stuff than propane. Water will push out all the propane gas, but resin will not flush clean.
   / cut open a propane tank #6
I wouldn't do that unless I filled it completely with water first, then drain and cut. I would still be worried about it. I had an empty 55 gallon barrel that had stuff to make fiberglass out of and was flammable., very flammable. It was old and dried when I got around to it, I had the bung open and was chiseling the top off but that was so slow, so I started cutting it with the welder or a 4-1/2 grinder if I recall. I don't remember which. All of a sudden I heard a rumble then a very big woof out of the bung hole. I think I soiled myself. Went back to chiseling.
Why did you go back to chiseling? All of the vapor had already been burned.
   / cut open a propane tank #7
My thoughts too :D It remembers me of the time i imploded a 1976 vacuum tanker by sucking the suction hose stuck on the bottom of the pit. The old lady couldnt take it and collapsed. a broken off axle U bolt sprung between my fathers boots, he jumped with both feet in the air and yelled "put that thing off, put that thing off" while i couldnt stop laughing whilst saying "now its too late anyway"
   / cut open a propane tank #8
I've never done it myself. I've read where people wash the tanks out with soap and water. Then plumb the exhaust from a diesel engine into the tank while cutting. A lot of people say never to use the exhaust from a gas engine.
   / cut open a propane tank #9
Gas engine exhaust is flammable with the right ratio of air.
Fill tank with water & drain several times. If the water can be heated even better. Nitrogen purge while cutting if possible.
If the tank interior is scaly, rusty, or has callcerous deposits on the inside think about different options.
   / cut open a propane tank #10
At the shop we used nitrogen after ventilating for many hours first...
2014 MACK GU (GRANITE) FUEL TRANSPORT TRUCK(INOPERABLE) (A50854)
2014 MACK GU...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2015 Dodge 5500 4X4 Bucket Truck (A51039)
2015 Dodge 5500...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2020 VOLVO VNL64T740 TANDEM AXLE MID ROOF (A51222)
2020 VOLVO...
400 gal Fuel Barrel on Skid (A50515)
400 gal Fuel...
