Cut a coupler
/ Cut a coupler #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
I have a 1.5 x 36" pipe that I will use as an extension to a 3/4" breaker bar for leverage. I also have a coupler to put on the pipe threads for a little more strength and to protect the threads and my delicate hands.
If I cut the coupler in half and use each half on both ends of the pipe, will the coupler survive the punishment of a stubborn rusty bolt? Will it crack and fall apart? Or will it last for ever?
/ Cut a coupler #2
If I am understand correctly the handle of the breaker is inside the pipe. If you cut the coupler in half and put half on each end there is going to be very little strain on the coupler. After all the pipe has most of the strain. The cheater is going to be way more strain on the breaker bar than anything.
Growing up around the oil field business a 3 foot cheater is on the shorter side
/ Cut a coupler #3
Go for it. The coupler will help strengthen the pipe and I've only seen pipe fittings ( I work with black pipe ) break when over tightened in a pipe threading machine or a bad fitting (factor defect in fitting)
/ Cut a coupler #4
It would half to be better than nothing. As long as the breaker bar handle is close to the diameter of the inside of the pipe I don’t think you’ll have a problem.
/ Cut a coupler #5
use a steel merchant coupler instead of a cast water pipe coupler,
most merchant couplers are straight thread and the ridgid or water pipe couplers have a tapered thread,
but there are steel and not cast, thus less prone to cracking,
/ Cut a coupler #6
Not sure of need of coupler on end that goes over breaker bar... Put pipe cap on end that will be handle If your delicate hands need protection (gloves?).... I prefer a cheater when forced to use it without any threads.... Always grab steel handle off floor jack....
Best bet if you need cheater bar often would be to get torque multiplier... I lucked out and got 4:1 torque multiplier at yard sale... You can put up to 250 ft-lbs on input and it will create up to 1000 ft-lbs on output....
Above image is for reference only...
TM has 1/2 dive input and 3/4 inch drive output...
Also consider when using cheater bar, if it fails under full torque load, you are freewheeling and it may cause you injury... This also applies to socket or wrench you are using to grasp nut or bolt if the fail...
No not safety police, but have learned to avoid pain whenever possible....
Dale
/ Cut a coupler #7
If your purpose is to be able to add another length as an extension, I'd recommend against that.
If your purpose is to eliminate sharp edges, why not just cut the threaded ends off and round them with a grinder?
But yeah, pipe to extend a breaker bar isn't always the best plan.
/ Cut a coupler #8
Yep... You can actually break a 3/4 inch breaker bar .... I know from experience.... That is why I have gone to Torque Multiplier
Dale
/ Cut a coupler
You're right, this is just to eliminate sharp edges without damaging the pipe so it could be used for other things in the future.
I don't plan on putting a large amount of force on the pipe. It's for making hard jobs a little easier without screwing something up. That is also why it is only 3' long.
New/Unused AGT Industrial SDA-140T Track Loader (A65579)
New/Unused AGT...
2016 Ford F250 Crew Cab Service Truck (A64194)
2016 Ford F250...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
Farmall Cub Tractor (A62613)
Farmall Cub...
2004 International 4300 Fuel & Lube Truck 593775 (A62613)
2004 International...
2018 Bobcat MT55 (A64126)
2018 Bobcat MT55...
