deepNdirt
Veteran Member
I have tried mounting 12 car tires on the front rims and really still cannot get a larger enough of a tire that would help in this situation, I don't like the idea of having to reverse the front wheels to achieve the wider stance do to the effect it will have on the wheel bearings, The FEL I have is 4 ft
and the front wheels of the tractor if set in normal position set at 37". This leaves the center of gravity a bit shaky when the loader is up while turning the tractor sharp one way or the other, so I have went ahead and reversed the wheels for now giving it a 43" wide stance, but do not plan in leaving it this way......
So here is what I have on my mind in attempt to resolve the excessive wear on the bearings, If I can take the center part of the tractor wheel and cut it out I would have the correct bolt pattern needed ,I would then re-weld it into the center of a larger wheel this would then give me more choices in use of a larger tire,.........
Has anyone ever tried and successfully built their own wheels by doing it this way? from say cutting the center from 1 wheel and re-welding into the center of another?
I have took measurements of the wheel center of the 12" tractor wheel and is 10 1/4 .... then measured the area from which would remove the center of a particular 14" car wheel that I have and is 10 5/8 on a 14" wheel this is a difference of 3/8 of an inch, but to center the 10 1/4 up into the 10 5/8 opening would leave a 3/16 gap to weld in all the way around, anyone done this without any ill effects? a 13" wheel might have closer to the same inside fit although I have not yet measured a 13" to find out... anyone have a 13" wheel on hand they could measure for me? I think by me building my own wheels I can adjust the center offset to what ever will be needed for the size tire I will use, the wheel I plan to use would be 6" wide. I would hope that I could simply weld it in at center of the wheel that being 3" This should allow a much wider tires for the front, although I would still have to use a low profile tire such as a 65 or under in order to prevent rubbing against the frame while turning sharply, does all this make since? wouldn't this resolve the issue of the front bearing wear? I know the weight from the FEL is still factored in as a contributor of the bearings failure, but if I limit my use of not keeping the FEL on all the time I think I can prevent the wheel bearings from wearing out,
All input is welcome and took into consideration
Thanks Folks
Thanks Folks
