custom hyd resevior
   / custom hyd resevior #1
Anonymous Poster
Epic Contributor
I am trying to find out how I can get a custom make hyd, resovior made for my 1010 with a loader. I get good pressure for what it is used for. just when I lift the loader above the tractor it seems like I run out of oil. I think if I add a extra tank I might get more out of it? any thoughts ( I also don't want to spend a lot of money. could I just go to a welding shop and get somthing made with black pipe welded on a box or inlets and outlets?
   / custom hyd resevior #2
I seriously doubt you're running out of oil. Why do you think this is the problem? I suspect you may just be seeing the limitations of lift due to the geometry of the loader frame. Very few loaders can lift as much weight to full height as they can lift off the ground.
MarkC
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
Wolverine Quick Attach Brush Grapple (A50515)
Wolverine Quick...
Sky Trak 10054 Legacy 10K Telehandler (A51573)
Sky Trak 10054...
Poly Round Bale Ring (A50515)
Poly Round Bale...
John Deere 400 Rotary Hoe (A50514)
John Deere 400...
John Deer 625F Grain Platform (A50514)
John Deer 625F...
