Cushman Mini truck governor help
   / Cushman Mini truck governor help #1
Nightrain
hampstead, NH
Cushman white truck
Hi new to the site but have read a lot already. I am in search of some info on my cushman white truck (mini truck) I just bought. Is there a way to remove the governor? The trucks that are imported do 45 to 50 from what i have read but mine doest 22mph. Any help would be great thanks.
   / Cushman Mini truck governor help #2
Welcome to TractorByNet. :tractor:
   / Cushman Mini truck governor help #3
:welcome:I know what they look like but cannot help with the problem.
   / Cushman Mini truck governor help #5
Welcome to TractorByNet!
I moved your thread to the Trailers & Transportation forum. :)
   / Cushman Mini truck governor help #6
google some more? The below info is nothing but 5 min of other forum posts that know much more about them than TBN.
seems there are various versions of this out there. Sounds like most of them are mechanical. Do you have a high range? some talk about a physical clip that keeps you from shifting to high range.
on others there seems to be some deleebob that from the speedo to the trans.
To disconnect the speed limiter is the easy part, just remove the sensor that goes between the speedo cable and the transfer case, and re- install the cable without it, I just zip tied it up out of the way.
   / Cushman Mini truck governor help #7
thanks can anyone help with my issue engine just died was told after checking the normal causes maybe gov. so wanted to bypass it
2008 WESTERN STAR 4900 (A45046)
2008 WESTERN STAR...
2017 Ford Explorer AWD SUV (A44572)
2017 Ford Explorer...
2025 Kivel 48in Skid Steer Forks and Frame (A44571)
2025 Kivel 48in...
2012 CALICO TRAILER CONTAINMENT TRAILER (A45046)
2012 CALICO...
Adams 5-Ton Ground-Driven Fertilizer Spreader  Reliable & Field-Ready (A44789)
Adams 5-Ton...
Goodyear 1400R20 Tires & Rims (A44502)
Goodyear 1400R20...
