tlj87
- Joined
- May 29, 2006
- Messages
- 439
- Location
- PA
- Tractor
- JD 4700, Kubota BX2370-1, Kubota RTV1140CPX, Kubota F3060, Club Car Precedent
I decided to replace the linear actuator used as a lift on the used Curtis snow plow I picked up for our Kubota RTV 1140 this summer. I had larger skid shoes added to the Curtis snow plow (From a Kubota BX snow plow) and the linear actuator could barely lift it.
I used existing parts from the Curtis setup including fittings and couplers from the hydraulic angle kit, the wiring harness and relay from original electric lift.
I ordered the following parts, all from Surplus Center:
QTY ITEM# DESC
(4) 9-6314 1/4" NPT QUICK COUPLER
(1) 916-1430 1/4" X 30" X 1/4 NPTM X 1/4 NPTM 3000 PSI HOSE
(1) 916-1424 1/4" X 24" X 1/4 NPTM X 1/4 NPTM 3000 PSI HOSE
(4) 9-5924 1/4" NPT QUICK COUPLER TIP
(4) 9-6806-8-6 SAE 8M X 3/8" NPTM 90 ELBOW
(2) 9-6805-6-4 SAE 6M X 1/4" NPTF 90 ELBOW
(2) 9-6405-8-4 SAE 8M X 1/4" NPTF ADAPTER
(4) 9-5405-4-6 1/4 NPTM TO 3/8 NPTF ADAPTER
(2) 9-5404-4-4 1/4 NPT HEX NIPPLE
(1) 9-7706-4 1.5X4X1 DA HYD CYL PINHOLE
(1) 9-5117-A SAE 8 6 GPM DOUBLE SELECTOR VALVE 12 VDC P155544-2
I also had three pieces made by a machinist (my generous, helpful neighbor):
1 mount for the hydraulic block, 1 adapter (2 pieces) for the hydraulic cylinder to mount to the plow A-frame, and 1 bushing for the hydraulic cylinder.
A video demonstration of the final product may be seen here: https://www.youtube.com/watch?v=zMo_ZmdSXKs&feature=youtu.be
QTY ITEM# DESC
