Anonymous Poster
Epic Contributor
- Joined
- Sep 27, 2005
- Messages
- 29,678
Some folks have asked me for more info and pictures of my Curtis cab on my new BX2200 so I thought maybe a new topic would be in order.
This cab is the softsided model with the two speed heater. I think list for this package is about $1800 not including installation, which I'm told is a lot of work. For you big guys, the seat DOES go all the way back with some room to spare behind. The cab is wider than the original deck width by a couple of inches on each side so I doubt that would be an issue. The roof of the cab is slightly higher than the ROPS bar and when measured from the deck to the head liner you have 55 1/2". From the middle of the seat to the head liner you have 38 1/4". I'll leave it to you to figure out if that's sufficient for you. Exiting the cab does call for you to have to lean forward some and duck.
Everything on the tractor appears to function just as it normally would, including opening the hood, except that I realized yesterday that taking the loader off may be a bit trickier because of the hydraulic controls. The cab "wraps around" the joystick and the cab has a solid cross member mounted in front of it. It appears that only three bolts hold the joy stick assembly on the loader frame so it adds a step for removal but not a major one.
The heater is GREAT! /forums/images/graemlins/grin.gif I didn't ask if the alternator or battery had been upgraded to accomodate the extra electricals in the cab but it doesn't show up on the invoice so I suspect not. The heater, BTW, is tapped into the cooling system like your car heater so all that needs power is a two stage fan. The heater has a water shut off for the summer when you might not want hot water flowing through the core! Included is a shroud to cover the radiator grille so the engine fan won't suck all the hot air out of the cab.
If there is something I missed in my description feel free to ask.
Here's a picture looking in to the cab facing back.
