Buying Advice Curtis cab for Kubota B7300
   / Curtis cab for Kubota B7300 #1
tgjendem001
Kubota B7300
I am considering buying a used Curtis cab for my B7300. It is a Curtis cab for a Kubota B2710 or B2910 (1KB2710SS Soft Sided Deluxe). I am wondering if it would fit my B7300. In the current series of cabs that Curtis sells, the same cab model fits both B2710/2910 and B7300, so these tractor models must be similar in physical size. Any thoughts?
   / Curtis cab for Kubota B7300 #2
I was looking at those some time back. Had the same problem you have. Current designs overlapped with my tractor but old styles wouldn't work.
Curtis has changed their newer cabs design to fit a broader range -- that is they are less specific now. In the older models, the cab to fit the B7300 also fit the B2410. The B2710 and B2910 are both larger overall than the B2410. The 1KB2710 model was specific to the B2710 and B2910.
If you could find the old model numbers 1KB1700AS or 1KB1700SS they would fit your B7300. The 2710 model is too big for your tractor.
Here's info on the old models/styles that you mentioned and what other tractors you could cross-reference from.
1KB1700AS fits
Kubota B-1700, B-2100, B-2400, B-2410,
B-7300, B-7500 (Hard Sided Deluxe)
1KB1700SS fits
B-7300, B-7500 (Soft Sided Deluxe)
1KB2710AS fits
Kubota B-2710, B-2910 (Hard Sided Deluxe)
1KB2710SS fits
Kubota B-2710, B-2910 (Soft Sided Deluxe)
CH4Ohio,
Thank you for your reply. Per your recommendation I will pass on this cab - see if I can pick up one that will fit the tractor better.
2009 Jordair Marines-320-DH Trailer Mounted Air Compressor (A51691)
2009 Jordair...
Hustler Raptor Limited Zero Turn Mower (A51573)
Hustler Raptor...
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
JOHN DEERE S780 LOT NUMBER 36 (A53084)
JOHN DEERE S780...
Lift Gate (A52377)
Lift Gate (A52377)
LOT NUMBER 251 (A53084)
LOT NUMBER 251...
