Currently have an L-3800. Need some yard tractor input.
   / Currently have an L-3800. Need some yard tractor input. #1
Rail Dawg
Currently have a Kubota L-3800 that I used on 10 acres of land. However that land is being sold and I'm moving to a house with 2 acres of lawn.
Is the L-3800 simply too much machine as a yard tractor? What if I got a nice finishing mower attachment instead of the heavy duty mower attachment?
Any inputs welcome.
Thanks.
Chuck
   / Currently have an L-3800. Need some yard tractor input. #2
L3800 is a lot of tractor for two acres, however you already own it, which is a huge advantage. If you have other potential tasks such as moving snow, I'd be tempted to hold onto it. If not, I'd sell it now and buy something more appropriate for the place.
If it turns out to be too much (here in Texas no snow) what would be the recommendation for mowing and towing smaller loads on 2 acres?
Thanks!
Chuck
   / Currently have an L-3800. Need some yard tractor input. #4
Really depends what obstacles you need to mow around. Smaller garden tractor mowers usually do better than 3 point mowers, which do not follow ground contours as well. My advice if you have other chores that the L3800 could do, keep it. And find a Kubota G3200/G4200/G5200/G6200 garden tractor. They are amazing mowers. :)
Are the G-series a good way to go or do I need something like the T-series?
Thanks.
Chuck
   / Currently have an L-3800. Need some yard tractor input. #6
I do not know about the newer G's. The T's are AWD when the front wheels are straight, and 2WD when they are turned, at least I think they are.
   / Currently have an L-3800. Need some yard tractor input. #7
I could see a BX being a good compromise if you still had tractor stuff to do -- they are great mowers. Or maybe a B. An L3800 would be clumsy for mowing smaller lawn areas, especially around trees/etc or wherever you need a tight turning radius.
I'm on 4 acres out in the country with an L3200, but I have a smaller Deere tractor for mowing my lawn (was my only tractor at my previous home in town). The Deere is 14 years old and seems like it will last forever.
I previously had a B2920 and it was fine for the most part, but moving firewood was tedious with the smaller bucket, and I'd occasionally run into other loads I couldn't lift. The L is bigger than I need most of the time, but I have never felt it was too small like I did with the B on occasion.
So I'd say it's not so much the acreage, but what you need to do on the acreage that might determine if you need to keep the L and add a mower, or simply trade/sell the L for something smaller like a B or BX.
   / Currently have an L-3800. Need some yard tractor input. #8
If at all possible, I would keep the L-3800 and add what you need to mow. If you find out later you do not use the L-3800, then sell it.
   / Currently have an L-3800. Need some yard tractor input. #9
I would look at a commercial 60" ztr for my mowing needs.
   / Currently have an L-3800. Need some yard tractor input. #10
Rail Dawg, I think s219 is right on the money. Your situation sounds exactly like what a BX or a small B is made for.
2007 International 7400 Chassis Truck, VIN # 1HTWGAAR87J437650 (A51572)
2007 International...
2015 FORD E350 16FT BOX TRUCK (A52576)
2015 FORD E350...
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
