Jul 21, 2014 / Curl leak on John Deere 4410 #1 C chief tom New member Joined Jul 21, 2014 Messages 1 Location West Melbourne Tractor 4410 The curl function on my John Deere 4410 leaks down. The corresponding function on the rear of tractor also leaks down. Is there anything that can be done short replacing spool valve?
Jul 21, 2014 / Curl leak on John Deere 4410 #2 J_J Super Star Member Joined Sep 6, 2003 Messages 18,952 Location JACKSONVILLE, FL Tractor Power-Trac 1445, KUBOTA B-9200HST Sure, one or more piston seals are leaking in the curl cyl. Same for the 3pt, piston seals leaking. It is possible that valve spools can also cause leakdown.
