This thought process began when I realized my sunroom has sunk due to a drainage issue I thought I fixed last year. The problem with my house and really most in my area is the soil seems to be mostly clay so water collects very easily. Plus for whatever reason block is used in most older home construction up until about the '80s as I understand it, which is what my house has and it can move when water gets behind it, so keeping water away is sort of crucial.
So the first big project I have is each and every downspout needs to be drained away from the house, to the street with french drains. At the same time, the back corner of my lot is a low spot that needs to be drained either to the street, with a dry well, or possibly a combination (still trying to research this). My rough calculations for the ditches that would need to be dug are about 200 feet total. One thing I am uncertain about with those trenches is the house had a septic or mound system at one time, but that was at least disconnected because it is on public sewer and has been since I moved in, my fear is somewhere in my yard are remnants of that system, but don't really know for sure.
So while the above would be a lot of large single-time projects I also have some reoccurring work. I have what I consider a fair number of large planter spaces, basically areas with various plants scattered all around my yard. For reference getting these cleaned out by someone professionally is about $1800 which is more than what it cost last year.
Some smaller items that I have thought about is I have a small utility trailer that my current lawn tractor can move but makes a lot of noise when I do, it is well within what the BX is rated for and I am thinking the lawn tractor may be on borrowed time each time I use it to move the trailer.
So curious if this application seems like one that would make sense for this machine? Any other thoughts would be great as well as I am sort of back and forth on whether this makes sense?
