Curious about the CK35
   / Curious about the CK35 #1
toddler
North Carolina, USA
Previously: Kubota B2710. Now Deere 3520
Hi,
I went and looked at Kioti tractors again last week. Happened to be in the right area, but sadly that dealer closed at 3pm on Saturdays. So I didn't get to ask for a quote. The Kioti CK30 HST on their lot looked like a nice sized tractor, and looking online, the CK35 HST is a tractor I'd consider buying. I didn't think the CK30 was as nice as the Kubota L3540, which is currently my favorite, but it is a little smaller, and I suspect it costs significantly less given Kioti generally sells more for less.
I won't be out near that dealer when they're open for several weeks, and I don't like asking for a price quote by phone, (I'm currently working out of state) so I figured I'd ask here. Does anyone know about what a CK35 HST with turf's, the mid PTO option, a MMM, and a FEL might run?
I know what the Kubota would cost me, and while pricey, it's in the range I'd pay. You can get some good deals on Kubota here in NC :). But if the CK would be several thousand less, I'll drive back to check them out again, and also to meet the dealer.
Thanks,
Todd
   / Curious about the CK35 #2
You are going to have to have the dealer search for a mower deck for it..
Kioti does not have one available for it unless the dealer does a search and locates a deck at another dealer you may be buying a Kubota.
I know that Del Moria is making one so if the Kioti dealer is aggresive he may just be able to work with you.
Hi Wallace,
I don't doubt you know your stuff, but Kioti clearly show a MMM in this:
http://www.kiotitractor.com/attach_files/Products/CK25_35_Catalog(5).pdf
Do they only make one for the CK25, or do you think that is a prototype that may be introduced soon? I'm perfectly happy buying various brand 3pt hitch impliments, but I don't think I want to get into buying an aftermarket MMM.
Thanks,
Todd
   / Curious about the CK35 #4
I have a penny or two to throw in here....
Just in case you didnt realize....
Kiotis are quite a bit heavier machines than "average" and I can only think of one poster here running a MMM on one. And the concensus seems to be that the Kioti is pretty heavy for soft lawn duty.
Then there are the considerations of changing out the MMM when unwanted.
It's more of an undertaking to remove a MMM than a RFM. Some actually prefer the RFM to the MMM.
Like I said....in case you weren't aware.
Hey Tony,
Thanks for the input. I am aware of the weight, but the other tractor in the running is about 300# more. I'd get it with slightly wider turf tires on the Kubota than the Kioti wears, and the lawn won't be very soft.
Also, I used to run a MMM on my B2710, so I am aware of the issues in removing the deck. But as long as I can pin it up and run the PTO for the MMM separately from the rear PTO, I'm happy. And heck, even if I can't, I can alway disconnect the PTO fitting for the impliment.
Regards,
Todd
BTW, I'm only about an hour away from you right now. At least I think that is correct. I'm working in Charlottesville for a few months.
   / Curious about the CK35 #6
Not that I can help you out with your situation, but when I was at the Tulare Ag show last month, I was looking at a CK35 and it sure is one nice machine, very comfortable and controls are in the wright place, for me anyway.:D It would be on my list of tractors to buy if I was in a position to get another tractor.
Hi,
I have another question in case Wallace sees this thread again. Is the mid PTO on the CK's independent, or semi-independent. It sounds like on the L3240/3540, to run the mid PTO you have to have the rear PTO turning. That seems pretty dangerous to me even if you have nothing attached to the rear PTO.
I wouldn't consider it safe to drive my little garden tractor around with a running cordless drill taped to the back, so the idea of having a 28HP bit spinning back there all the time kind of irks me! I know the JD is completely independent, and I think the NH's are, but can't find anything about the kioti online.
Thanks,
Todd
   / Curious about the CK35 #8
My Kioti has a cover that screws on over the PTO shaft if your not using it. I don't know if it's spinning or not most times. I'm sure others are the same or similar. Assumptions can be dangerous sometimes.
Steve
:) Who's assuming anything? I'm asking?
My B2710 had a plastic cover too, although I never actually screwed it on because the rear PTO didn't spin when the Mid PTO was turning. They were independent from each other like on the JD3520. I think the NH tractors are also completely independent.
The Kubota brochure says that with the independent PTO, both the mid and rear PTO can be activated independently without stopping the tractor. But that could be read as they are independent from the tractors motion and not each other. Then below that on the page it says the mid PTO is a semi independent dealer installed option. Someone here posted you can't run the mid w/o the rear PTO turning.
So I'm curious as to how the Kioti works. I'm also wondering more about the DK's. I really think they may simply be TOO big, but they have a MMM that appears to run off the rear PTO. That's a great way to simplify things. Can you pin the MMM up and just disconnect the PTO if you want to use a 3pt hitch impliment on a DK?
Thanks,
Todd
   / Curious about the CK35 #10
Thanks,
Todd
I didn't think there was a MMM for the new DK line. The tractors are pretty big to use as dedicated finish mowers so it would be a bit odd.
I just checked the Kioti website and you are correct that they seem to have a 72 inch MMM listed under the DK35 and 40 however the photo they show is definitely not a DK and the specifications for the MMM indicate not more than 20 PTO hp so I think there is a screwup on the website (not the first time). I'm guessing that MMM is the one designed for the CK20 and that is exactly what the tractor looks like in the website photo.
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
Electric Concrete Mixer (A51573)
Electric Concrete...
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
2021 John Deere 9420R Tractor (A53342)
2021 John Deere...
2017 Ram 4500 Bucket Truck (A53472)
2017 Ram 4500...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
